Mapping (top left position) of a screen or a projector on a canvas can’t be adjusted manually and doesn’t save
Positions of video screens and projectors on a canvas (set up in Canvas setup window) can’t be adjusted manually and upon save & open of the project are reset to 0,0.
Steps to reproduce
  1. Create a video screen or a projector and a canvas
  2. map the screen to the canvas in the Source tab
  3. double click the canvas to open its setup window
  4. double click on the video screen to map it onto the canvas
  5. try to adjust the x & y value using the textbox. The position won’t change.
  6. Move the screen to something else than 0,0.
  7. Save and open the project and the screen will be back to 0,0
Workaround
None known
Fixed in
3.5.1
Art-Net (eDMX) fixtures don’t work with throwers
Art-Net (eDMX) fixtures cannot pull content from throwers (perspective nor orthogonal). This has been caused by the upgrade of throwers in 3.5.0.
Steps to reproduce
  1. Create an eDMX fixture and a thrower (of either type)
  2. Open the Source tab of the fixture and you’ll see the thrower is not listed there.
Workaround
None known
Fixed in
3.5.1
