Art-Net Reader node crashes on node select if port 6454 is taken
If port 6454 is taken by a different UDP Reader node or a 3rd party software, an enabled Art-Net Reader node causes a crash when you select it.
Steps to reproduce
  1. Make sure port 6454 is taken (receiving) data either by UDP Reader node or by a 3rd part app.
  2. Create an Art-Net Reader node and check its Listening/Streaming checkbox.
  3. Select the node.
Workaround
Make sure the port is not taken when you enable Art-Net Reader node.
Fixed in
3.5.0
