When you insert a large number of nodes (for example, more than 150) into one Layout, the GUI becomes broken depending on the zoom level. An example of a broken GUI of a layer layout Steps to reproduce Create a layer Create a large number of nodes (usually more than 150). Depending on the zoom […]
Continue readingArt-Net Sync is not working
Sync to Art-Net timecode is not working at the moment. Steps to reproduce Open a sample project Go to Sync tab and check Sync to Art-Net timecode The transport will start moving although it shouldn’t as there is no incoming timecode. Workaround None known yet. Let us know if you are having trouble with this […]
Continue reading
