OSC Writer crash if port not available
OSC Writer crashes if port is not available. Steps to reproduce Set up an OSC Reader so that it listens on a specific port. Set up OSC Writer to the same port, but don’t enable the Streaming checkbox yet. Set up an OSC Sender in Layouts so that it is sending some value to the […]
Continue reading
Vertically Flipped Texture on OBJ imported objects
When applying a texture to an imported OBJ UV mapped object, the texture was flipped. Steps to reproduce Insert an imported OBJ object into the Visualizer Create a Texture Variable Apply this texture variable as the Source of the imported object. You’ll notice the texture is vertically flipped. Workaround Use a Texture Flip node to […]
Continue reading
Lightact reverts to Free license despite dongle
On some computers, Lightact sometimes reverts to Free license with watermark despite a dongle with a license is plugged in. Steps to reproduce Insert a USB dongle and Run a project Lightact will, on some computers, for a minute or so, switch to Free license. Workaround None known. Fixed in 3.2.3
Continue reading
