Lightact will crash if you type in 0 to resolution width and height for any object in the VIsualizer that has resolution input and hit Apply. Steps to reproduce Create a canvas In the Res x input type in 0 and press Apply button. Workaround None known. Fixed in 3.2.3
Continue readingOSC Writer crash if port not available
OSC Writer crashes if port is not available. Steps to reproduce Set up an OSC Reader so that it listens on a specific port. Set up OSC Writer to the same port, but don’t enable the Streaming checkbox yet. Set up an OSC Sender in Layouts so that it is sending some value to the […]
Continue readingVertically Flipped Texture on OBJ imported objects
When applying a texture to an imported OBJ UV mapped object, the texture was flipped. Steps to reproduce Insert an imported OBJ object into the Visualizer Create a Texture Variable Apply this texture variable as the Source of the imported object. You’ll notice the texture is vertically flipped. Workaround Use a Texture Flip node to […]
Continue readingLightact reverts to Free license despite dongle
On some computers, Lightact sometimes reverts to Free license with watermark despite a dongle with a license is plugged in. Steps to reproduce Insert a USB dongle and Run a project Lightact will, on some computers, for a minute or so, switch to Free license. Workaround None known. Fixed in 3.2.3
Continue readingCrash when re-scaling imported objects
Lightact crashes when you try to scale an imported OBJ object along the red axis. Please note: this bug might appear with other workflows too. Steps to reproduce Create an empty project import an obj file select it and press ‘t’ to switch to scale gizmo try to scale along the red axis. Workaround First […]
Continue readingCrash when checking/unchecking Streaming checkbox of Audio output node
Lightact crashes when checking/unchecking Streaming checkbox of Audio output node quickly if a Source device is selected. Steps to reproduce Create an Audio output node and select a Source device on the right. Check/uncheck Streaming checkbox repeatedly and quickly. Workaround Click slower. Fixed in –
Continue reading
