If you set the Loop boolean input to false and save the project, it’s going to be set to True when opening. Steps to reproduce Insert a HAP Video Reader node Set its Loop property to false save and open the project and it’s going to be set back to True. Workaround Use a Bool Constructor […]
Continue readingChanging the resolution of a Thrower/Video screen with eDMX fixtures mapped to it causes a crash
Lightact crashes when you change the resolution of a Thrower or a Video screen that’s set up as the source of a Fixture or a Fixture placement. Steps to reproduce Create a Thrower or a Video screen Create an eDMX Fixture or a Fixture placement Set the Source of the Fixture or Fixture placement to […]
Continue reading
