Video player displays last frame after loop
Video reader node (and most likely other video playback nodes) too, displays last frame before refreshing back to the first frame after looping. Steps to reproduce Create a looping Sequence. Place a layer with an active Video reader node in it, but don’t put it at the beginning of the Sequence. When the transport loops back […]
Continue reading
Blob tracking node is broken
Blob tracking node is broken. Steps to reproduce Connect the node to a cvMat source and its cvMat output to a cvMat to texture node which should be connected to Render to canvas node. the texture won’t be passed to Render to canvas node and Lightact will probably crash. Workaround Not known. Fixed in 3.1.1
Continue reading
cvMat resize node is broken
cvMat resize node is broken. Steps to reproduce Connect the node to an active IP camera listener and cvMat to texture node which should be connected to Render to canvas node. the texture won’t be passed from IP camera listener to cvMat to texture node Workaround Use Texture resize node instead. Fixed in 3.1.1
Continue reading
