Texture rotate vertically flips the texture that’s connected to it. Steps to reproduce Create a Texture rotate node Connect a texture source to it. Leave the Angle at 0 and you’ll notice that it’s vertically flipped. Workaround Use a Texture flip node after. Fixed in 3.0.5
Continue readingSpout sender vertically flips the texture
Spout sender vertically flips the texture that’s connected to it. Steps to reproduce Create a working Spout sender. Connect a texture to it. In an external Spout receiver observe the texture and you’ll notice that it’s vertically flipped. Workaround Use a Texture flip node before Spout sender. Fixed in 3.0.5
Continue reading
