When you insert a large number of nodes (for example, more than 150) into one Layout, the GUI becomes broken depending on the zoom level. An example of a broken GUI of a layer layout Steps to reproduce Create a layer Create a large number of nodes (usually more than 150). Depending on the zoom […]
Continue readingCrash when trying to stream audio to an audio device with non-english alphabet
If the name of the sound device is not in English letters, then the program crashes when you try to ‘stream’ an audio device. Steps to reproduce This has been reported by a user using a Cyrillic alphabet. The crash occurred when selecting an Audio output node, selecting a Source device with a non-English name […]
Continue readingCrash when setting a too large resolution
Lightact crashes when you set a resolution that’s too big for your graphics card. Steps to reproduce Create an active Texture generator node (for example color to texture) Increase the resolution input. Depending on the maximum resolution (and possibly available video ram) Lightact will crash. Workaround Not known.
Continue reading
